vcWedgeFeature
The Wedge geometry primitive generates a wedge-like shape with the specified dimensions. The basic shape is a cuboid that is truncated with a plane parallel to the Y axis that intersects the far X - Y(top) and Y - Z(front) faces, at specified distances along the X and Z axes, respectively. This shape may then be reflected through the X - Y(bottom) plane, the Y - Z(back) plane, or both.
Module: vcFeatures
Parent: vcPrimitiveFeature
BiggerHeightvcRealExpressionPropertyR
Access expression value via vcRealExpressionProperty
Gets or sets the Z-axis height of the wedge's back end.
BiggerLengthvcRealExpressionPropertyR
Gets or sets the X-axis length of the wedge's bottom.
MirrorBackBooleanRWGets or sets the mirroring of the wedge along its X-axis.
MirrorDownBooleanRWGets or sets the mirroring of the wedge along its negative Z-axis.
SmallerHeightvcRealExpressionPropertyR
Gets or sets the X-axis length of the wedge's top.
WidthvcRealExpressionPropertyR
Gets or sets the Y-axis width of the wedge.
